So my rear end is a half inch lower on the rear drivers side. Does this go away after an OME lift or do you need a trim packer or two on that side to level things out?
you didint put the longer coil on the wrong side i hope
Only if you work out... :lol:
im having this problem with my OME setup and have been deciding if i need the trim packer added too. Wat im wondering is if i have to take the entire front strut apart or does it just fit somewhere not integrated so i dont have to re-compress the struts. I dont really wanna get another alignment and yes i put the long coil on the correct side. I checked twice before putting it in. Also wondering if u get one for the rear also?
Chadman: i would say get it bc from wat i could tell from ppl on here. Ull need at east one if u want it to sit almost perfectly flat.
That's normal. I blame the gas tank and I keep my amp and sub on the opposite side to try to even things out. I think a trim packer would be a good idea. You should notice a difference in the front as well
