lost power steering suddenly
Simmer
Member
Hi guys - was up in the mountains over the weekend and lost power steering suddenly. Dumped all the fluid out. Not sure why, wasn't wheeling or anything crazy but the dirt forest service road I was on is bumpy, rocky, etc. The entire section under the hood near the pump is wet with oil, not sure where specifically it's leaking out but it's not a slow leak.
I had about ~100 miles to get home with zero power steering. What is the probability I burned up my pump running it with no fluid? What about my rack? I'm taking it to the dealership tomorrow to fix, but since they're piece-rate I'm not expecting any forward thinking - just fixing the leak and moving on. Should I be worried about my steering rack or any other part for damage?
Rack should be ok, since it doesn't seem like the seals on the rack were the point of failure. It was on mine and there was no brining it back. The pump is just mechanically driven so there's no risk of 'burning out the motor' like on an electric pump. I suspect the dealership will replace it anyway. You should be fine after the repair.
Thank you! I appreciate your time in reply. Someone had mentioned to me about metal shavings from the pump going into the rack, wasn't sure if that was a large concern or not. Yeah I don't mind if they replace the pump at all, in fact I'd prefer they do just to be safe.
That's really going to depend on what failed and why. It's hard to say if your rack is okay or not, but I'd be willing to guarantee that your pump is toast.
Dealer said the seal(s) within the pump itself failed, so new pump. Lines are still good. Said they'd flush it so I'm hoping rack is okay too (nothing bad getting into rack from the failed pump).
Thanks again guys! :)
What's the damage for a new PS pump at the dealer?
They haven't told me yet, I told 'em to just order it. I'll let you know what they say when I get it back!
A new pump from Toyota retails online for about $300. The dealer will most likely mark up that price to near MSRP of $461. Add in 3-4 hours of labor, fluid costs, and taxes, I think it will cost somewhere around $950.
I agree with gamefreak with pricing. I have no idea why the vane pumps are so expensive OEM.
not knowing your skill levels. but its not a difficult job and pumps can be had for under 150 at auto part stores
yes you should flush the system
I would have cut the belt if I blew a pump in the middle of no place
Shoot, I didn't even think of this. I think that's smart, I should have done this! I will if this ever happens again...
tuṣṭāva
