Loud bang randomly 03 v8
Moist
Member
It's coming from right next to the transmission, just aft of the engine where the two mate. It feels like something kicks the floor rather hard.
It consistently happens immediately after the car stops, and sometimes about 30 seconds after the engine stops. It does happen intermittently while driving, but it is usually drowned out by the cacophony of other noises.
It is accompanied by a misfire on occasion, but this is only during startup. (90% sure I need new plugs)
I thought it might be the exhaust, but I can't get the play required to force it to make the sound/impact something.
I'm not sure what causes it, and have been chasing it for about two or three months. I really don't know what could be moving that much when the car is off to do that. Any ideas?
(EDIT: I'll get a video of it later.)
Do you not think it could be the slip joint on the drive shaft, it's known to clunk when stopping when it needs greasing, try greasing the Zerk fitting on the slip joint until you see slight movement this usually solves the problem.
I would agree except I've never had it happen while driving. I experience a "bump" sometimes when stopped at a light. It happens whether I just greased the slip joint or whether it's time to grease it again. (I don't put as much grease in there and that seems to have stopped the bump. Like AuSeeker says, add grease until the shaft moves.) The other time is when I back out of my driveway (maybe 25') stop and put it in D. I let it roll forward and I get a little bump most times, especially first time each day. It doesn't do it anywhere else so maybe being parked on a sharp rise like my driveway has something to do with it.
I wouldn't classify either of those as being a "kick", just a slight bump. Still, I agree with the slip joint. Have you greased it at oil changes along with the U-Joints?
You say you get an ocassional misfire, I wonder if you getting some raw fuel in the cat and it's igniting? You should get a falshing check engine light though I would think.
If it's not the slip joint it's probably something expanding due to heat from the exhaust. Perhaps a heat shield mount or something. I'd put it on stands let it get hot and then get underneath and see if you can localize the noise.
Thank you all for the replies, been a bit busy and haven't been able to check up on the post.
I do not think it is the slip joint. While it certainly needs grease and occasionally kicks, it only does it from stoplights and when shifting into gear.
The banging happens regardless of gear. It mostly happens during startup or not long after the car has been shut off when the car is only in park or neutral. There shouldn't be any stress on the driveline and so I can't see why that would produce the same effect. I'll still grease it as it does need it.
I will check the exhaust, I know one of the heat plates is damaged. My exhaust dropped out aft of the muffler a few years back and we just welded the chunks back together. Maybe the damage was more severe than I thought. I don't know what could make it that violent, but I'm exited to see. I think this may be it, as the noise and kick in the floor happen after the car is off when the exhaust is cooling.
The misfire is occasional and does not yield a flashing CEL. It is a sudden drop in RPM (It only is a second or so) with a odd faint noise that sounds like smacking the neck of an empty 2 liter bottle. This is followed by a small surge in RPM before normalizing a few seconds later. This only happens on startup and even then its uncommon.
I did have a small engine fire a few months back. After the repairs I never checked the exhaust header that caught on fire and I wonder if that's doing something. I'll take work off this weekend and take a look at the exhaust and see if I can capture the misfire on an OBD II scanner.
Also check both engine mounts and the transmission mount. It feels like something knocking against the floorboard is what's making me think that your drivetrain is moving under load or under decel. Also during startup the engine moves quite a bit from a dead still.
My engine mounts aren't great. Not bad enough to need replacement yet but still not stellar, the frame mounts are more rusty than I'd like. Trans mount seems alright though.
It has to be the exhaust now that I'm looking at it. I can't get it to move much though. I have a suspicion it has to do with something heating and cooling rapidly, hence why it also does it when the car is off.
Perhaps it is warped somewhere and the heat and pressure from the exhaust is suddenly pushing it back into shape. Afterwards it crumples back into the deformed shape. I suspect wherever it is has some form of physical damage or warping, most certainly from the fire or exhaust drop. Cezar I think you might be onto something
I have ruled out the driveline. Under further inspection it doesn't make the noise when under any load. I'll be greasing the slip joints still.
Otherwise I've been trying to get it on camera but it just keeps eluding me. (That or I forget again)
Thank you all for the help thus far!
AndiGarage
