Love my 4-Runner, but...
azynprswazyn
Hi -
Just wanted to see if people had some thoughts on what I should expect to get for my 3rd Gen '96 5-Speed Manual 4-Runner.
I really need a truck, so I'm looking at Tundras, but need to decide if I should sell the 4-Runner or not (we already have two cars in addition to it).
The Good:
It's a white SR5 with rear diff lock. A couple of months ago, I changed the UCA's, did a Toytec 3" lift and the lower ball joints.
It also has leather seats, the cup holder conversion and a Tacoma whip antenna to replace the broken electric one.
I put the 17" Tundra Split Spoke wheels to go over the Tundra brake upgrade and also have fairly new Goodyear Wrangler Duratrac tires (<5000 mi).
I also have the diff drop and a 1" body lift that I haven't had the chance to put on yet, in addition to new crystal headlight housings and corners, and TRD headers.
The Bad:
I'm pretty sure it needs a new head gasket -- as you can see above, I haven't had the time I need to devote to her.
There's also a dent in the lower part of the driver's side door and the running board from the previous owner and she does have some rust around the front windshield and a couple of other small areas.
Lots of good and lots of bad, so I'm not quite sure what a fair price would be.
I have a couple of pictures that show the drivers side and before/after the lift.
Any help would be appreciated.
$1500-2000
Nothing in the "Good" column amounts to much added value.
Everything in the "Bad" column is going to kill the price.
Rust + leaking head gasket = Project or parts truck.
Best of luck to you.
$1500-2000
You're kidding right? Do you know how rare manual 4runners are with an e-locker? I bet even with needing a new head gasket (if that's your only issue) you can get $4k. Maybe more idk but I say $4k is a safe bet. It doesn't look like it has a 3" lift in those photos though.
That's a nice looking 4Runner. I really like the tire/rim combination. Take off the running boards. They are dragging down the appearance. You did not say what your mileage is. That's really what determines the value. I think $4000 too if it's about 200k.
Thanks for the input, guys. I'll probably hang on to it. I'll just have to find some time to change the head gaskets. [MENTION=53465]Nervo19[/MENTION] I want to take them off but need to find a solution for getting the wife in the truck. She hates it as it is. It's got about 180k on it.
Well, now that you've brought "the wife" into the situation, you have your answer. Just do whatever she says!
Jesse1
