LowCel's 2012 Blizzard White SR5
A fellow track day junkie. That is the main reason I drive the 4runner as well. To pull my 05 GSX-R 750 to all the Texas tracks and NOLA.
Cheers!!!
0098B7D9-BBC2-4A8A-A4CE-8EF93A203822_zpsqzyaen1p.jpg~original
Another fun day working on the stereo system. I was having some problems with clipping so I decided to go with an after market head unit after all. I must say after finishing the install I am very glad that I did. My only complaint is that the factory steering wheel controls for the phone don't work.
I went with a Kenwood DDX-372BT deck, a Pioneer ND-BC6 back up camera, and an Axxess ASWC-1 steering wheel control interface.
ADC39BDC-6510-4B54-99F0-737CCEABE9B4_zpscxh1uldq.jpg~original
First step, wiring harness. All soldered and heat shrinked.
A40451F0-0D49-4EA8-8098-A25DAF446013_zpshlmwejqn.jpg~original
Next was mounting the camera. I went with mounting it on the hitch. I figured if it is good enough for Randyman it is good enough for me. I really wish that there was an adapter to allow me to use the factory camera but apparently there isn't.
6E12EE12-F881-4C5D-A511-467ECE13B2D2_zpsoz4eqyu5.jpg~original
I ran the wires through the same grommet that the inverter wires go through (also thanks to the advice from Randyman). I had to loosen up the rear panel but I did not have to remove it.
96FEDC01-1F3E-461F-84EC-F13E4A2CE984_zpsqcf6lstz.jpg~original
The wires for the camera, remote turn on, and the wire to go to the back up light to turn on the camera all run down the passenger side.
Apparently I forgot to take a photo of the passenger side so here is a picture of the driver's side showing the RCA cables. For now I am running some cheaper cables, that may change down the road.
E5A0E84F-B95C-4093-8769-9E5739841F9E_zpspg24fnvr.jpg~original
2010AA80-CEF8-4AEA-BC81-586A7DF1AFB1_zpsrkbalsrx.jpg~original
I've got to be honest, the Scosche Installation Kit was a bit of a pain in the ass. The main problem was removing the air vents from the factory mount. Once I figured that out it wasn't too bad.
624187FD-9506-49BD-BDEF-4B0388C04359_zpsstknbnri.jpg~original
Here is the OEM deck beside the Kenwood.
C28F9BCD-A797-4A48-948D-7783215F3D1C_zpsbtm943bx.jpg~original
Finally, all installed and back together. I do have to take it back out tomorrow to install the antenna adapter and the USB adapter. Sonic told me they were sending me the antenna adapter with my order, I guess they forgot. I ordered a USB adapter but managed to order the wrong one. Oh yeah, I also have to hook the factory deck back up for a minute so I can remove the CD that I left in it. Oops.
52D797B0-A4F9-419F-9161-0A23BAF9545E_zpsepx2oxdc.jpg~original
96590A08-5376-44BE-AC2D-CF3A134BCE77_zps1ucxnfqr.jpg~original
I also finished the flex loom on my power wire under the hood.
BF8C3C75-2C16-442F-8719-FF6051D6CA93_zpsigvwhc8g.jpg~original
3C403718-897C-4051-8CB1-9D70B5BEF1F4_zpspaea2etd.jpg~original
So what u going to do with the OEM deck?
Okay, I'm to the point that I hate the running boards. Are the N-Fabs pretty much the way to go? I won't be doing any serious off roading if that matters.
Well until I decide on N-Fabs or something else I decided to just remove the factory running boards. It looks so much better.
4before_zpst0apdgde.jpg~original
4after-1_zpsgelyhpuu.jpg~original
what did you use to keep the fuse block from moving on top of the fuse box?
My new wheels arrived today, now just waiting to receive the Bilstein 5100's and rear Daystar spacers. I'll be getting the new tires towards the end of the month, beginning of next month.
wheel_zpsnlvvlhe5.jpg~original
6ADB5062-2F26-4260-9A2B-407ACC0D29E2_zpsdql4keae.jpg~original
I was bored so I cut out some decals.
DA403BDB-A8A6-4FA5-AEE2-3D19FD95A752_zpsacndqrrj.jpg~original
Now I have to decide which style I want to use to cover up the center cap on my wheels.
Because this "8" isn't going to cut it.
center%20cap_zps2rcnl6ou.jpg~original
Time for a quick update. I went with Bilstein 5100's all the way around. The fronts I set to 2.5". The rear I went with Daystar 1.5" spring spacers. For wheels I went with Level 8 MK6's with Nitto Terra Grappler G2 285/70R17's.
I also went with the front inner fender mod and removed the front mud flaps.
4runnerafter2-1_zpshz8o5v0u.jpg~original
Jhunt
