Lower Ball Joint on its way out?
EricHartley
Hey so I noticed this today, figured I'd get some input from you guys.
I just replaced mine, and it was black and dirty with no grease though. I had difficulties at first, but once I had the right tools, it took me less than an hour to do one side. Make sure you have the right tools and it'll be super easy (I recommend renting out a kit from advance auto parts called the front end service kit because it gives you different sizes of tools).
When looking at my old ones with 250k miles, they weren't loose at all, but I thought'd I'd change it out to be on the safe side.
Thanks for the replies fella's.
Revelc, that's what I was thinking. I did jack up the truck and tested them by prying on them and neither were loose or had any play. (Only one side is showing grease)
I live up in Vancouver Canada and we have suddenly received a bit of a heat wave, ( now this is a stretch) but could it be the grease in the joints responding to the heat? Or do I sound like an idiot for thinking that haha.
The truck is at 245k kilometers (156k miles)
Change both with Toyota parts only.
This. Do it now, spend the $180 on new Toyota parts and bolts. Rather than spend thousands later when your wheel falls off, rips your CV out, breaks your steering rack, destroys the fender, wheel, and tire and possibly you.
I second that. Do not buy anything but OEM. My drivers side lower ball joint just sheered off the other day. Luckily I was only turning into a parking lot so I wasn't going very fast. I had replaced that one two months ago with one I bought from Oreilly's. Thats less than two months from a ball joint without offroading, just driving to work and back. I called the dealers today and OEMs were about $130, wishing I had spent the money instead of trying to save.
Camelback is the cheapest & free shipping over $100. I paid around $87 each. They come with the castle nut but you have to buy the 4 (8 total) bolts separately.
Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
I just ordered a new set after one broke on the trail. I ordered off of toyotapartznet.com since they offer a 10 percent discount. spent 200 on 12 bolts, both ball joints and an extended warranty, good for 36 months
*** We will only ship to the Customers billing address ***
NO International Shipping.
OP is in Canada. He'll have to go with something like Toyota Parts Direct - Your Canadian Source For OEM Toyota Parts Online | Toyota Parts Direct
So it'll cost him:
1 JOINT ASSEMBLY, LOWER BALL, FRONT LEFT . JOINT,BALL 4334039465 $130.08
1 END SUB-ASSEMBLY, TIE ROD, RIGHT . END,TIE ROD 4504639335 $41.70
1 END SUB-ASSEMBLY, TIE ROD, LEFT . END,TIE ROD 4504739215 $41.70
1 JOINT ASSEMBLY, LOWER BALL, FRONT RIGHT . JOINT,BALL 4333039585 $130.08
8 BOLT . BOLT 9008010066 $1.49
That's $272.08 or $355.48 CAD depending on whether he does the OTREs too.
utkrstam
