Lube Change Question.
Koz
I will be changing my diffs. and transfer case oil soon and I was wondering if there are any gaskets needed?
Koz
Boaz said:
I thought I would post up the part numbers for the crushwashers. I had to go to 3 different dealers to get these damn things. Hopefully this will help someone out in the future!
Front Diff Drain
9043024003
Rear Diff Drain
1215710010
Transfercase Drain
9043018008
Oil pan drain
9043012031
Hopefully this will save someone the headache it caused me.
Total cost was almost 7 dollars for 2 of each.
Koz, here are the part numbers for the gaskets on the V-6 Im sure most of them are used on both V8 and V6 models but calll a dealership you trust (LOL!) and have them verify. ALso I had to special order several of them so be prepared for that. Total cost was 7 bucks for all of them.
Let me know if you need any more info.
Jake
Also there are crush washers for the fill holes too. I didn't change those but there are two for each diff. and two for the t.c. if you want to change them on both the drain and fill holes.
Transfer case fill gasket 90430-18008
Transfer case drain gasket 90430-18008
Front differential fill gasket 12157-10010
Front differential drain gasket 90430-24003
Rear differenyial fill gasket 12157-10010
Rear differential drain gasket 12157-10010
these are what I got from the dealership exploded diagrams...
Transfer case fill gasket 90430-18008 rough looking steel gasket
Transfer case drain gasket 90430-18008 rough looking steel gasket
Front differential fill gasket 12157-10010 metal crush gasket
Front differential drain gasket 90430-24003 larger brass gasket
Rear differenyial fill gasket 12157-10010 metal crush gasket
Rear differential drain gasket 12157-10010 metal crush gasket
I'm actually making note of these so it's easier for me in 30,000 miles or so, but I thought you guys may want a description too. I should have taken pictures, but I suck at life and neglected to do so...
also, when it comes down to how many quarts to buy, I bought 8. I used most of the eighth too, as I would leave the drain plug and the fill plug open and shoot some new clean oil through whichever vehicle part I was working on, just to try and flush out anything that may be hanging out in the case. clean oil in and out, then I replaced the drain plug and filled her up. seemed to work okay, and it's worth the price to be certain.
