ZandT4R
So everything was going great until reassembly. I found out that the ball joint puller actually crushed the end of the rod going to the ball joint (all the same piece?). Where the holes are cut for the cotter pin is an extremely weak point and the puller crushed the end of the ball joint at that weak point. There is probably about 10-12 threads there and the bottom 4 are toast. Luckily the top 6-8 are still ok and they do all the work so now I am in the process of grinding off the crushed part so I can get the nut past the bad threads and to the good threads. Also the cotter pin will still be usable so I think everything will be good. I was scared at first because apparently you cant purchase just a new ball joint you have to get the whole upper control arm. At the price of the control arm I am better off just upgrading control arms to something like the camburg or the total chaos.
This really sucks though as I have only worked on the driver side so far and am afraid the passenger side will do the same thing.
Anyone have any advice? Or possibly a ball joint they can send me?:bash:
