Making a flush rear cargo area
kott3670
Hey Ya'll, So I've seen a lot of threads on different sleeping area builds with storage built into the back but can't sacrifice that much cargo room... I'd really like to be able to sleep in my truck while camping and don't have the stock rear sliding cargo pull out that is a factory option....
First question- I haven't been able to find in any searches adding the rear pull out tray- Is it possible to do? I see myself actually using it a lot and would really like it / not mind getting raped by the dealer to install
Second question- If the first option isn't possible, what is the easiest / least intrusive way you have done or seen to be able to make the rear cargo area flush with the rear seats down?
Thank you!
My first question is whether or not you're short enough to sleep in the back of your 4Runner with the tailgate closed? To me that makes or breaks an in-vehicle platform, reason being the necessity to move all your gear around each night.
I had the sliding cargo tray on my last 4Runner and when extended it's far from a flat sleeping platform, you'd need to craft some sort of sleeping platform for it. You'd also have to unload all your gear outside which some people don't mind but it could be problematic in inclement weather and expose your stuff to varmints and/or bandits.
Of all the sleeping systems I've seen, the most cost-effective method for folks who don't want to be in a tent is a roof-mounted awning with a cot. Quality cots in my opinion are very comfy and make for a legit, functional camp setup. One of my friends with a 3rd gen runs that setup exclusively and it's quite nice.. no climbing up and down out of a roof top tent and no need to re-organize all your gear when you break camp.. just stow the cot and roll up the awning. Just food for thought.
kott, there are a couple threads about adding the sliding decks, which a number of people have done. The dealers won't be able to do it, since it is not an optional add-on. Your only way to get one if you already have a rig without is to trade your standard deck pieces with someone who doesn't want their sliding deck.
If you're not able to source one, this is the cleanest (non-sliding) setup I've run across. It's a simple build and is perfect for what you're after. Note that picture is posted in one of the threads about adding the sliding deck, so click out of it to see the rest.
I am actually in the same boat as you. I really want the sliding deck for the same reason, as I'm ready to buy a '17, but they aren't available on what I'm after without KDSS and in my color preference. So, I will be having to go that alternate route until I might be able to find someone to swap with. Who knows, I may prefer the custom option better.
I'm not at all sure what Sparky is going on about, as those remarks are off the wall to say. Going back to the second generations, simply remove the seat bench, then a 6' 6" guy should fit without a problem. I've got 677 nights in my '02 doing just this setup without having the need to move much gear around. That's certainly more cost efficient than an awning and a cot, not to mention less time to set up, and less gear. Note that this is for a single person setup. Obviously, if you had two, then absolutely, gear would need to be rearranged all the time.
Thank you!
Flat cargo area /sleeping platform- click below
http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-11.html#post876313
Hey Antman, I'm in the planning process of building a setup similar to your second version (split cargo cover). Do you think it's necessary to pull out the carpet, foam and padding? I would prefer to just set the unit in the cargo area without pulling out all of that stuff and losing the sound deadening. I don't have a 3rd row or cargo slider.
You'll probably be fine. You just need to find a way to properly secure it and provide a good base. I took all the carpeting out too though because the hull of the body on the 5th gen is a little deeper than the 4th gen, so you have about a 1.5-2 inch thick piece of styrofoam in there. and I preferred to not worry about it's compression and then subsequent loosening of any bolts.
Also been looking at simple ways to comfortably sleep in the back without too much hassle. One idea I liked while searching around was this lightweight cot.
http://www.amazon.com/dp/B01M61RXH6/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1UDQO85TX3TF&coliid=I3L3964RFUD1YW
I haven't done the measurements, but saw pics from other members. Cot dimensions are 74x28x15. You could store stuff under the cot, which seems like a plus.
I also like Dude's setup up there. Simple and comfy looking. Plus, like he said, you would have more headroom.
There was, a little while back, a thread where a guy purchased a slide out cargo tray from another member and installed it in his 4R. He included pics and as I remember it was a lot of work.
You don't have to pull it all out but you won't have any storage space...
CVT Tent
Get a CVT tent!! They're built for any weather and are very durable. I live in Bend and went to their showroom. Once my new 4Runner comes in, I will be purchasing for summer! They even have heaters for them in the winter.
Here is a step by step guide on adding the sliding rear cargo deck
http://www.toyota-4runner.org/5th-g...argo-tray-install-pics-steps.html#post2601767
Thank you!
Thank you!
I've thought about creating a thread with all the inspirations I got when building mine because I spent a few months figuring out exactly what I wanted to do. I didn't want to lose a ton of space in the trunk, and I wanted a platform because there was a little kink where the seats went down that I could feel through my sleeping pad when I slept back there in colder climates while camping with the wife.
Give a look at my build and hope that gives you some idea. Ended up going with a drawer that I keep in permanently now (although I can remove it as its not bolted down), and then a detachable platform that makes it flush with the drawer. It's only about 8.5" tall so I do lose some space while sitting down but is good enough sitting on top with a slight hunch.
Link here:
http://www.toyota-4runner.org/5th-g...ystem-sleeping-extension-build-[5th-gen].html
Mitz_170226_9803_COPY_INSTA_zpsshxubfzb.jpg~original
Mitz_170226_9800_COPY_INSTA_zpsq7ucikx5.jpg~original
Thank you!
I have a rear sliding tray w/all the hardware I will be putting up for sale, but if you are just looking for a level flat surface, it would be cheaper just building one like the link a antman's post.
Nice mod [MENTION=65614]Antman[/MENTION]...
I'm extremely interested and not in a rush.... So if you could PM me price and whatnot Maybe we can work out a deal! Thanks for the Response!
And I love the 2X2" blocks of wood and 1/2" plywood..... Will be a great temporary solution and gives me something to screw down my Subwoofer to.....
I think I may eventually build a full rear storage system with slide out trays You all have shared with me, Nice thing about that is that I can Fabricate in a sub box directly into it as my current one is way to small for the sub I have.....
I swear you all are just out to steal all my money and make me mod my truck to the point I will be in debt the rest of my life!
I love the 2x2 idea in the meantime as I am trying to buy a crappy car as a commuter to keep miles off the 4Runner as this is a vehicle I plan on actually keeping more than 2 years for once! I'm in love with this thing and blame you all for my monthly payment!
Just to add to the conversation. I too have been looking for the Toyota sliding cargo deck. I reached out to Toyota to see if I could get special pricing/package price instead of buying the 12 parts separately. Ford gave a friend special pricing years ago. In summary Toyota told me Toyota doesn't recommend or assist altering their vehicles. I understand Toyota's reply and don't want to make this about Toyota.
Best deal I could find on the parts is $1,360.49 + tax/shipping, list $2,391.83 (ouch).
Pull the rear seat bases out and there is more room, enough for me to sleep straight. Extra storage space in the footwells too.
I did the Antman cargo mod and could not be happier with it.
