mass air flow sensor replacement
spartacus
Senior Member
MAS bad on a 2000TR4. Does someone has a url or instructions "how to"?. Have some idea but want to be totally sure before i try it. Dealer Price is $183.93 is that good? or should i go for after market refurbished
You can clean a MAF operating out of spec and sometimes bring it back into proper specs. If replacing I would go with a new OEM one though. What code did you get?
The code was P1130.Replaced MAF with OEM denso and the two O2 sensors also denso. all is good now. Drove over to Silver lake over Guenalla pass about 11,700 ft in altitude(colorado)The actual peak is closed but you can still go around. The truck ran like a champ. Ropeman was a great help in helping figure this out.
Replacing the MAF was unnecessary if only P1130 was present. P1130 is related to the A/F sensor. At least you got everything fixed and hopefully for not too much $$!
