Hello All,
I have an 88 v6 4runner. I am having clutch issues. After inspecting the hydraulic system, it was discovered that the flexible hose was visibly leaking and the slave cylinder also. I have installed new ones of each. I then bled the system. However, i can not get any pressure in the line. There is air in the line and I dont know where it is coming from. All the fittings and bolts are snug. Is it possible the metal hydraulic lines are leaking somewhere or at the fittings (where they attach to flexible piece)? Is there a way to check or isolate the leak. I dont want to have to replace the master if not necessary.
When I am bleeding the line, after the new flex tube and slave are installed, how many pumps of the peddle, while filling master, should it take to clear out all the air. I pumped at least 30-40 times and was still getting large air bubbles with every pump. I am using a bleeder jar and hose for the job.
the clutch now has very little resistance and is much worse then when I started.
Please, any help is welcome.
bomhour
bomhour
