Matt's build thread
Nicely Done Matt! Doing the same TC setup w dual Kings, eventually, just have to find the time. What was your ball park install time? This is my daily so I will have to make arrangements for that. Also, where are your fastener points on either end of your limit strap? I see the clevis and tried to zoom in but can't really tell.
Hopefully this photo will work for you.
I forgot to mention I also added a daystar spacer in the rear. Here are some shots on hows she's sitting.
Update time!!!
Needed to cut and re-weld the rear bumper. The tires were hitting the bumper pretty good when flexing. Took off about 3/4 of an inch.
Once getting the rear long travel dialled in I hit a local trail. It was definitely one of the hardest trails Ive been on. It showed me a lot of weak spots I needed to work out on the truck. Some of which I believe were my fault. I bent both my tie rods, broke 3 tire beads, bent my slider, my cv boot clamp fell of my drivers side CV, friends broke my bumper hoop with my high lift, flattened the cam tabs and cracked a rim.
I believe my tie rods bent because I didn't tighten the adjustment bolts once the straps stretched out. Wont make that error again!
My twin compressor was a life saver. I was able to inflate the tire back up and popped the bead back on. Popped the bead once going up this part and twice doing back down. I was pretty surprised with how easy it was to get the tire back on. I need to rethink my tire/rim choice.
I didn't get as many photos as I would of liked, but I did get some videos I can post up later.
Some photos of the damaged/repairs.
Should have done these at the same time as the LCAs.
It was pretty sad to see my new shocks beat up so fast. So I came up with a solution.
Made from 3/16 steel.
Here are some flex shots... needed to make sure the shock guards wouldn't be making any contact with something they'er not suppose to.
Couple more photos from the last wheeling trips.
Did a little install this weekend.
Not gonna lie this was pretty sweet haha. :50cal:
Couple Pew Pews:
- Bergara B-14 HMR in 6.5 Creedmoor
- Mossberg 590A1
- Keltec RDB
- Ruger PC9.
044runner4
