Max Recommended Front Lift, Center Hub to Fender
assassin
Was wondering how much lift you guys recommend "maxing" out at in the front. Currently I am at 22.5 center of hub to fender. I went to a meet and saw people with as much as 25 inches in the front. I am sure more lift in the front with stock axle shafts means worse CV life.
i wouldn't go by how much lift you can get, but more along the lines of how much of an angle your cv boot looks like. Everyone is different.
I went up to 3 inches to fit tires, now I'm actually going back down as much as I can to maximize my cv's life.
I agree with this.
This thread got me checking and mine measures center hub to fender @ 23 1/8" . Too much?
Do you want a show truck or something functional?
For functional height - 3 inches is kinda the limit. Higher than that and you should be either going for a bracket lift or long travel.
For a show truck that doesn't really do anything very well - you could maybe get away with up to 4.5" lift if you clearance your CVs and use a diff drop. It's going to suck on and off road. But it can physically be done and move under its own power.
I think that's fine. But again, check your boots to see how angry they may be.
I am down to 23.25 from 23.5 and the ride and breaking is so much better.
When my lift was freshly installed I was at 23 inches my boots currently look pretty good I think I could afford to go a little higher in the front but don’t think it’s worth the work adjusting 1/2 with kings
maybe im uninformed. Checking your boots your just looking for tears/angle and stretching ya?
Im at 23 with a diff drop. Hope to go up 1/2" more when I get my icons.
To see if and or how much the boots are rubbing (looking for tears and slung grease is also a good practice every so often as well). If a business card can fit between the bellows you are good to go. Now..everyone has their own comfort level with this, so everyones appetite will be different on this.
Here are a couple of pics of the CV @ 23 1/4" . To my untrained eye, all looks well. Comments?
How hard are the boots to change should it come to that?
I don't have any first hand experience with it myself.
From what I've read it's a messy job and some sent the axle out for the work to be done.
I do know of folks that run with the boots the same or worse than yours (and mine) who are at 80K miles with no issues at all. I was at the dealership yesterday in fact (getting alignment because I reduced the preload on my coil overs) and there were new lifted 4Runners on the lot with angles and boots that were much more severe than yours or mine.
I think 23.25 inches in the front is fine.
Why not remove the inner small clamps, pull the boots further down the shaft (closer to each other) and re clamp? That would stretch them and stop them from rubbing on themselves and wearing holes in them. With the ribs touching each other, they're going to wear out even faster.
At droop I think it may cause them to overstretch
