Max tire size for 16x8 on 2006 SE
Hello,
I'm planning on getting some 16x8's for the winter time, and i was just wondering if anyone could suggest the max tire size that i could fit with a 3/2 spacer kit. I'm planning to go with some BFG Mud Terrains.
Thanks,
AJ
Search is your friend. With a 3" lift and the right offset/bs rims you can fit 285/75/16s.
If you have a sport edition you can't use 16" rims, they won't clear the brakes.
285/75/16 MT will be tight. You may want to to consider 275/75 or 265/75.
Also, AT tires are usually a bit smaller than MT so the BFG All Terrain in 285/75/16 would be a better fit.
