35,000 Hard Miles on this one!!
Got this Stock Rig Yesterday. This will be a Quick Build up Since I already have all the parts.
The Beginning:
Belly:
Front:
Cargo:
Parts:
Rollers:
The Wheels are the ones I am using, Just not the same offset...(I know someone will notice the high offset ;-) )
Info:
I went out on a limb with this truck and Lift. Did my own research, R&D, etc. Use at your own risk. :cheers:
Price: about 550.00 shipped
Pro Comp FJ Cruiser 3" Suspension Lift PN: K5074B
ProComp Springs are Similar to OME FJ Heavy Duty Springs F&R
3 inch Lift Kit with ES Shocks
Lift Height: 3 Inches (4.5" on 4Runner)
Front Lift: Coil Springs
Steering Correction: Not Required
Rear Lift: Coil SpringsIncludes: Sway Bar Brackets and Related Hardware
Shocks: Front ES6000 Spring Seat Shocks and Rear ES9000 Shocks
Shock Boots: Not Included
Max Tire Size (Inches): 33 X 12.50
Wheel Size Range (Inches): 17 + Wheel Width Range (Inches) :8 to 9
Min-Max Backspace (Inches): 4 to 4.75
My Notes(so far): Needs a front Diff Drop, and maybe HD Upper control Arms/Ball Joint
The Beginning:
Belly:
Front:
Cargo:
Parts:
Rollers:
Info:
