MIL Eliminator, anyone got one?
You mean you want to clear the check engine light? Disconnect the battery for 15-30 minutes or buy any cheap OBDII scanner and that will do it.
Lol, yeah I can clear it but it keeps coming back, as for the URD option its kinda on the steep price but... I guess if its my only option.
Just recognize that the URD sim is only for P0420. It is GREAT for that--but that's all it does. Do you know what code was thrown? Sometimes you actually had better FIX the problem--if you value your ride--rather than just make that pesky light go away...just sayin'.
The catalytic converter went bad when I flooded my engine so Im cutting it off and welding a pipe there, its only a P0420 so nothing wrong with the engine.
OK, sorry, just wanted to make sure you knew what you were doing. Make sure you leave the rear O2 sensor in place, as the URD sim will not work without it. I have seen discussion of a DIY sim, but I don't believe it is regularly done. It would require a microprocessor timer, and is not a trivial circuit.
This puppy is out there, but I have no idea if it works:
Universal O2 sim
I think it is a true sim, as in, does not require the operating rear sensor, but I am not sure. You may want to read this thread, which goes into the issues but without providing any real resolution. O2 Sim installed and still getting CEL??! - Page 2 - CustomTacos.com Forum
I think I would just go with URD which we know works.
