Mild Lift w/ KDSS
dproberts
I want to do a mild lift and I was thinking about the TRD Pro suspension. However, now I'm thinking of the following:
SWAY-A-WAY 1.5" LIFT REAR COIL SET (SAW 102-1575-195)
5160 REMOTE RESERVOIR REAR SHOCK SET (BIL 25-227611)
TOYTEC/BILSTEIN 5100 ADJUSTABLE COILOVERS (TTAFCS-2005KDSS)
FRONT DIFFERENTIAL DROP KIT (TAC-DR-05)
Any thoughts? This seems better and cheaper than the TRD Pro kit. At what point is a diff drop needed and new uca needed?
This will not work.
You won't need a diff drop bracket , the UCA are really only needed if you are wanting them to clear tires/wheel combos with different backspacing or are not able to get your alignment (caster) back into specs.
I wish I had more information to elaborate on the previous posters "this will not work" comment. May have to do with mixing 5160 rear shocks with 5100 fronts but I thought they were similar with the 5160 series having a remote res. Not sure though. Someone who looked into the Bilstein kits more then I will have an answer for you.
Because all bilstein products are on back order haha
im running this same setup with (no diff drop needed) and regular bilsteins. no reason you cant go with a different shock of your choice for the rear
