Mileage Meter Off with different tires
NViejeP
Hey guys, can I get an approximation of how much the mileage/trip meter will be off.
Right now I've got 31x10.5x15 tires, my stock are 225/6X/15.
Will it be neglible?
Borrow a portable GPS unit and compare the vehicle indicated speed to actual. The percentage difference my vary at different speeds.
Koz
You can buy an interface which will calibrate it. A few simple wire cuts and splices...
I saw it on YT, if you need I can go find the product.
Cheers
Mark
Koz
how exactly is that possible?
Cheers
Mark
Superlift makes a calibrator like you're talking about.
Saw one in a JC Whitney catalogue, part # AJT556443
$189.95
GPS will give you the actual speed based on your movement and the triangulation of several satellites which you can compare to your indicated speed.
With my MTR's my GPS speed (actual) as an example, can be 80mph whereas my indicated speed (speedometer in car) shows 76mph.
Problem is, I don't know how accurate the GPS is. As an example mine is supposed to be accurate within 20ft of location but I don't know how this translate to speed differential.
I do know that before I changed tires, my GPS and speedometer read within 1mph difference.
I think he was questioning this part:
And I'm not sure if that's possible. I think the larger tires will change the final drive ration and it will be a linear percentage difference from 0-what ever top speed is.
I took off the stock 28's on my truck and replaced them with 32"'s and my speedo is off about 5% across the board. I have driven with a GPS to verify that too.
A GPS is the only way to figure out how much it will be off.
Yep, that's the part I'm wondering. The only way the percentage would be variable would be if something in the system was variable, such as the tires getting larger or smaller while driving or something.
On my truck, I went from 32" to 35" and used an online calculator to determine how bad the speedo is off. I wrote down the more common road speeds and their conversions on a piece of paper and taped it to my dash :D
When someone gets in my truck for the first time, always the first question is: what the hell are those numbers for?? ha :D
if gps is not available, have somebody drive another car and you both cruise at the same speed and see how off the speedometer is.
When Changing tire size the percentage difference is linear. When I went from stock 265/65r17 to 265/70r17 the difference is aprox. 5% based on my GPS. This means that when my speedo says I'm going 100km/h I'm really going 105km/h and when it says 50km/h I'm really going 52.5km/h.
The difference between your speedo and your actual speed will depend on the size of your tires. The calculator form 1010tires mentioned earlier in this thread will give you a rough idea of that difference until you can check it against a GPS or another vehical.
