Minimizing rust on under carriage
Jersey Woods
Any ideas on minimizing rust to the under carriage of vehicle
I was thinking of alot of things
One being, painting the old drained engine oil onto the parts of the bottom of vehicle seems like a cheap method to get rid of rust
Any ideas
Jack it up, crawl under, clean. Clean some more, and then more. Remove any surface rust with a wire wheel. Let dry.
Take some rustoleum flat black and coat it. I suggest using the spray can even if you have a spray gun. The gravity fed gun can be a pain to use while laying on your back spraying up.
First off you will not "get rid of the rust" by coating it in oil. Rust doesn't react with motor oil. If you ever heard that someone sprayed their under carriage with oil it needs to be thicker than used motor oil and its a preventative method its doesn't not react or get rid of rust. Now since you must live in an area where they use salt the rustoleum method will not work that well for you. Rattle can paint is cheap and the best "rust reformer" will not completely react with rust, all it really does is cover it up. My frame is pretty clean for a Chicago car and i wouldn't think of painting with and rattle can paint because it will just bleed through. If your really serious about cleaning up your frame there are a couple products. Por 15 and rust bullet. They are expensive but the formula uses actual chemical reactions to convert rust to a stable form that doesn't spread. A friend of mine who owns his own business uses rust bullet to paint old rusted grain silos. Like I said its pricey, around 600 or so for 5 gallons, I'm not sure of thr prices for smaller containers but in any area that uses salt I wouldn't trust many other products. My plan is to jack the car up this summer, wire brush the whole frame so its free of surface rust, and then coat the frame with black rust bullet. If you want to ask someone who has actually done it I believe I saw that toytec's shop painted a customers frame with por 15.
Has anyone painted the under carriage - Hows it come out - the rustoleum method sounds about right to what im looking to accomplish - cheap and effective atleast somewhat long term
I patched things up with some black rust paint after wire-wheeling. I get it undercoated with the Rust Check stuff which is mineral oil I guess.
Want to do some POR-15 and more widespread under truck work, but the really important parts for me are inaccessible unless the body is lifted, which is way too much effort.
Any ideas
The 'Search' and 'Advanced Search' functions on this forum are your best friends.
There are a million threads regarding rusty frames, axles etc including this most recent one...
http://www.toyota-4runner.org/3rd-gen-t4rs/107459-its-rusty.html
Rustoleum will work but is definitely not a permanent solution - rust will eat it's way through it.
POR-15 is an excellent product and a little of their paint will go a long way but you MUST make sure you clean the area thoroughly and properly before applying. Fluid Film is a pretty good rust preventative.
I coat my undercarriage with oil. It does not remove old rust, but it will stop it from getting worse.
Pics of my undercarriage after years of oil coating. The previous owner never treated the undercarriage, but began and continue to do it every year.
P1110581.jpg~original
P1090040.jpg~original
P1080413.jpg~original
Is it messy?? YES. Will it save your undercarriage from become a piece of Swiss Cheese?? YES. Do you have to do it every year?? NO (I did it regularly for the 1st couple of years, but now do it every second).
This is the most cost efficient way I have found to save my truck from certain death! lol!
I also coat the chrome, rocker panels, and lower door edges with WD40 several times per winter:
DSCF6321.jpg~original
Looks bad in the winter....but looks like this in the summer:
DSCF5347.jpg~original
Not bad for a 14 year old truck in Northern Ontario Canada....
Known solution - Chassis Saver
Something I've been looking into - Fluid Film
I'm a fan of fliud film. Been using it for three years. It's expensive at $8 per can, less expensive if you buy in bulk. It smells nice and is clean. I use 2-3 cans in the fall. IMO It is unrealistic to get rid of existing rust. Best option is to control it. When you use fluid film it seeps into the rust and metal and protects it from rusting further. I buy mine on ebay. Farm inplement centers may have it too. It is hard to find at regular retailers like Home Depot and Farm and Fleet. Buy online.
I have been very pleased with the results.
MMJR_T4R
