daugherty83
Replaced the rear hatch cargo light tonight, and the switch is on the "door" position. It only comes on when you open the actual rear hatch door, and not with any of the passenger doors. Is this standard, or should it light when any door is open. Also, is the glove box light located behind what looks to be a plastic grille of some sort on the top of the insided of the box. The glovebox light that I found for my truck are tiny, and I have no clue where they go, lol. And last but not least, when changing the oil, is there a crush washer/gasket that needs replaced on the plug for the pan. I have read somewhere, some do and some don't. And does anyone have any thoughts about the high mileage engine oil, and if it is possible to cause leaks that you wouldn't have known about otherwise similar to full synthetics getting past aging seals and whatnot. Thanks in advance guys.
