Misfire problem on 2004 V6
Skyline
I got a CEL indicating a misfire on cylinder 4. Can someone tell me which cylinder that is?
Any suggestions on fixing this aside from checking the connections? Do these coil packs have a tendency to go (I have about 110k miles, and the plugs about 5k)?
When I've had a misfire before, it's tended to be a loose wire. But it could be any of the following:
  • Open or short in engine wire
  • Connector connection
  • Vacuum hose connection
  • Ignition system
  • Injector
  • Mass air flow meter
  • Engine coolant temp. sensor
  • Compression pressure
  • Valve clearance
  • Valve timing
  • PCV hose connection
  • PCV hose
  • ECM
As to which cylinder is #4, here's what I found: http://autorepair.about.com/library/firing_orders/bl-fo-1172.htm
:iagree:.....What plugs did you use? Also check the plug insulator for cracks.
