misfire with bad exhaust
apparently a misfire can be caused by bad exhaust. Does anyone have experience with this, and did fixing the exhaust fix the misfire? My muffler has been getting progressively worse and now I'm getting rough running and a misfire code. I'm hoping I haven't burnt a valve or something. I'm scheduled to get the exhaust fixed tomorrow but if I have more serious problems maybe I shouldn't bother.
Of course the misfire could be completely unrelated
I just replaced a ruptured muffler ( after I was running a straight pipe installed after my Catalytic convertor was stolen) no misfire issues when it happened .
All repaired now with new cat and muffler.
My misfire issue that came up once was a bad plug wire on one of the coil packs, the terminal inside the wire attaching to the head terminal in the coil pack was bad, replaced wires and misfire eliminated.
I just replaced a ruptured muffler ( after I was running a straight pipe installed after my Catalytic convertor was stolen) no misfire issues when it happened . .
I also have experience with misfires caused by other things, but I'm wondering about misfires caused by leaky exhaust
I could see that if the exhaust was either plugged or if the issue is upstream of one of the O2 sensors. Glad you got it sorted out.
Maybe. The CEL came back on and I haven't pulled the code yet. It was running great but I may have detected a misfire
The O2 sensor had lost its nuts and was just wobbling around and leaking. But I never pulled an O2 code before the exhaust repairs, just misfire code
It wouldn't throw an O2 code, it would throw a P0171 lean code. The O2 is one of two sensors that controls fuel flow and is vital that it is airtight.
Well it didn't throw that code either and it was so loose you could pull it out.
Vehicle ran fine yesterday after clearing the misfire code, so I'll just have to keep an eye on it
AndiGarage
