BobLMTDT4R
i've swapped coils, so I know its not them. I am going to try, weather permitting, to lurk around the engine and look over things. I find that if I just start it and drive, no problems at all.
bob
bob
Have you done a compression test? Did you change the spark plug wires as well? What brand parts did you use for coil packs/injectors/spark plugs?Sorry to ask on this thread - I cannot seem to start a new post yet -
99 4runner - 201K
I got a P0305 code. I went ahead and changed all the plugs, coil packs and injectors. It ran great for about a week but now is running rough again and just threw P0305 and P0302 codes. -
What else could it be?
99 4runner - 201K
What would cause (p0300, p0302, p0304, p0306) cylinder misfires only on the driver's side bank/even numbered cylinders, ONLY after running for 1-2 hours?
All the 220k service stuff was recently done; timing belt, water pump, all new gaskets, spark plugs and wires, all 3 new coils. All OEM Toyota parts.
I've searched all over this forum and others and can't find a single commonality with just the 3 cylinders on the one side... only when hot. I'm stumped.
Any help diagnosing this issue would be greatly appreciated.
Did you ever find a solution? Dealing with a similar issue and beginning to worry about ECU or some sort of control driver issue.Smoke test showed the vacuum hoses are all good, no leaks anywhere.
Not sure how to troubleshoot beyond this.
I agree that something wasn’t right after the timing belt, but the problem has meandered about as the parts have been swapped. It used to be a random misfire only after up to temp. Now it’s rough at cold start, but throws no codes until warm, then P0303. All spark plugs, wires, and coil packs are new and OEM. All injectors cleaned/replaced.
At what point do I give up and drop it off at a Toyota dealership?
