Mixing tire sizes front to back
Rave
I have X3 BF Goodrich long trail tires P265/65 R17 with 8/32" tread. Trouble finding a 4th. tire. Can I put X2 BF Goodrich Long Trail P265/70 R 17 on the back with the other size, in the same tire, on the front. Any help would be appreciated. Thanks.
might not be a good idea if your truck is 4wd.
did you know that 265/70r17 that size end up costing less than the stock size.
The 265/65 is 30.6" tall, while the 265/70 is 31.6" tall.
In 2WD it wouldn't make a difference, or in 4WD in sand/mud/snow/etc.
In 4WD on a hard surface you might notice a little binding.
I wouldn't do it with any full time system.
Just curious, wouldn't the 4th gen's Torsen center diff have no issue with unmatched front vs. rear axle speed (unless in locked mode of course)? In open mode, it's not like it has any clutch pack or viscous system that would wear out or cook in this situation.
Never mix tires on AWD
Mixing tires on an AWD vehicle can cost you big time down the road due to premature wear on drivetrain components. It doesn't take much and even if you don't feel any binding or hear noises it will cause problems later on. Rule of thumb is nothing more than 2-3/32 difference on all tires must be the same brand too coz not all sizes are created equal. Just for example trying putting on a brand new running shoes on one foot and a worn out shoe on the other foot then try running a full 26.2 marathon and you will know how your drivetrain feels.
Truth is it will probably be fine short term, but I wouldn't do it as a long term solution. It won't activate the Torsen diff right off the bat; but the Torsen diff, ABS, and ATRAC systems all activate at ~3-5% wheel slip. If your front and rear tires already have a 1% rotational mismatch (which they would at those tire sizes) you'll be closer to that threshold and those systems will activate unnecessarily and unexpectedly. Even if it doesn't damage anything it will probably annoy the crap out of you when your in a parking lot with tight steering angles and ATRAC keeps shaking the brake pedal and beeping at you.:frusty:
2001ATL
