Rock Slide
Senior Member
Selling my 1st gen roll bar out of my 3rd gen.
WabFab Off Road cut the rear feet to the correct length in order for the roll bar to fit in a 3rd gen. Rear feet were then re-welded at an angle in order to sit flush over the fender wells. Wabbit also built a custom set of 4 external mounting plates to give the roll bar a solid mounting point.
2 small holes were later drilled into the roll bar to mount a maglite. Roll bar was then dropped off a local powder coating facility and sprayed high gloss black.
Roll Bar Pad was cleaned up and a new black zipper installed by a local upholstery shop (what can I say, I'm OCD about the small stuff.)
Since I cut oem cargo liner to fit with the roll bar installed, figured I'd include it in the sale too.
Therefore, I'm including the following in this sale:
Roll Bar
Roll Bar Pad
Mounting Plates
Mounting Bolts
Maglite Brackets
And my cargo liner cut to fit!
$165.00 for the entire lot. Ships on your dime. If you're interested in a local pickup, I'm in B'ham, AL.
Full build thread can be found here: Roll Bar Install
Let me know if you're interested.
Bar:
Plates:
Pad and light bracket:
Liner:
Feet:
Roll Bar
Roll Bar Pad
Mounting Plates
Mounting Bolts
Maglite Brackets
Bar:
Plates:
Liner:
Feet:
