I hate to add to this already long thread, but there is some confusion on my part.....
For grounding the blue wire to a switch, that will allow rear locker in 4Hi, correct?
It will not allow rear locker in 2Hi, correct?
For rear locker in 2Hi, another wire (grey?) needs to be grounded via a switch as well. Yes? So does that mean two switches engaged for 2Hi and rear locker, or just one?
Can anyone clarify that for me? All the attached pics are perma-blurry... stupid imgur...
Bumping for myself..... Anybody figure out a locker with 2Hi?
Hello!
I have an SR5 and very interested in this mod for getting out of muddy situations. Don't have a locking differential but ATRAC activation in 2H would be enough to get traction. I noticed the CEL issue mentioned. Are we sure it's speed related? I was wondering based on the diagram if the 4WD ECU expects both the 4H and 4L inputs to be grounded rather than just the 4L switch. Any thoughts?
So in my experience using this mod for many years, flipping the switch and/or engaging the locker and/or ATRAC do not automatically flip the CEL on, it takes some time using it in that mode. So I'm not completely sure what feedback the ECU is getting that it doesn't like, I'm just guessing that it was sensing excessive speed while it thinks I'm in 4L. I may misunderstand you, but I don't think you'd want to ground both 4L and 4H at the same time as that would surely cause a confused ECU.
Hey LWN:
Thanks for the quick response! So in all your years of using it, you have seen no adverse effect? I am currently looking at adding a e-locker for the back and SoCal quotes are coming in at around $2,400 for an Eaton rear locker. The ATRAC in 2H mod seems a much cheaper alternative![]()
How hard is ATRAC on the drivetrain? I don’t really notice when using it but it looks a little abrupt in videos. Wondering if that is why there’s a speed limit.
I’ve found regular old traction control in 2wd is often enough until wheels come off the ground or things get start to get steep.
Honestly I don't know why Toyota limited ATRAC ... to 4L only.
Heat. The brakes can overheat even in 4L. Higher speeds, more heat.
I've seen several folks, in this thread, saying that this mod has worked well. But unless I missed something, it appears they all have 2014 or older 4Runners. In certain situations, I'd like to be able to use the rear locker or maybe ATRAC when in 4 high. I have a 2018 4Runner TRD OFF ROAD and I'm wondering if this mod is doable on my vehicle. And if so, is it basically achieved in the same manner? Any input or clarification would be greatly appreciated.
