Motor oil?
mavrick1903
Not trying to start an oil debate. Just wondering if there are any do/don't for oil change. I usually go to a local or a Valvoline cause it's easier. Synthetic, any other considerations?
Like [MENTION=66389]BlackWorksInc[/MENTION] said as long as it meets the API rating and proper weight pretty much all the oil brands are fine. Many people have brand preferences; but it's hard to find a 5W30 that doesn't meet the Toyota Spec.
The OEM oil filters are definitely the way to go; affordable and well made, you can even buy in bulk. I even managed to find the JDM 90915-20004 oil filters that came installed from the factory a few years ago and stocked up. At the oil change interval of 5k miles recommended from the factory, pretty much any conventional or synthetic will do just fine.
I like to run a full synthetic (Mobil 1), mainly because it doesn't thicken up as much in the cold. Conventional oil pours like molasses when it is freezing out. I also run 6000+ miles between oil changes, used oil analysis from both V6 and V8s has shown that the 5000 mile interval is quite conservative, and that most oils can go for 7500+.
Another +1 for the OEM filters (the commonly available 90915-YZZD3 ones). They are cheaper and higher quality than other store bought ones I've used.
