Motor Options
Animportant
Hello, I've been reading several threads.. looking for an up to date answer on what some of the forum members here would do if they were in my shoes.
Picked up a 97 4runner, blown motor (one of the heads is busted). It has oil all over the darn thing, so I'm assuming it needs to be resealed.
Would you:
A) Replace the motor
B) Compression test and possibly just replace the one head and reseal it?
If you were going to replace the motor, would you:
A) New/rebuilt motor? Where would you source this?
B) Junk yard?
C) Something else
I would replace the engine with a used / yard engine with warranty or with a JDM engine (can be a bit more of a pain)
You can pick up a nice used 5vz-fe for 800-1200 bucks depending on the mileage of the motor at a salvage yard. I recently had to replace mine.
My only concern with a yard engine is that I'll have to reseal it and throw a timing belt kit on it at some point in the near future anyway (esp if it has 100k miles).. what do you guys think? Just maintain the older motor as i go along?
How may miles in the engine already?
Low miles, get the heads done with factory gaskets. High miles, may be a low mile engine. Do a compression test before buying from a yard. Harbor freight tools sells those devices.
With any engine replacement you should put in a new timing belt, water pump, and all that goes with it. Very easy to do with the engine out of the car.
Wound need a lot more specifics on the old engine and what actually happened to determine if it is worth saving.
Edit: With 250K, I would just buy a JDM or yard engine with half the miles. Do the basics, install and roll on for a long time.
Yea, just throwing another 3.4 in. I'm not very mechanically inclined, pretty much learning everything as I go with this 4runner. I have found a motor with 99k miles on it for $800. I'll probably pick this up.
Hmmm Have u had it diagnosed to determined how bad the issue is. I mean if the head is just blown I would think it would be easier to just do a head gasket job than pull a entire motor... :playball:
tuṣṭāva
