multi terrain select not working
I replaced the front actuator yesterday and now the 4 wheel drive light flashes rapidly and the multiselect terrain indicator light is on and has knocked out that function....I have full function of the 4 wheel drive despite the light being on.... could I clear the lights by disconnecting the battery?
probably damaged something during the install or forgot to plug something back in? check this thread, seems to the same or similar issue you are describing
Warning lights: Multi-terrain Seleft and Four-wheel Indicator lights flashing | Toyota 4Runner Forum [4Runners.com]
So... With the dash lights still flashing I went into a snowed in driveway and pushed my way through deep snow.... after I visited for a while I started back up and all lights were off and everything fully operational....I had things checked out after the weekend and there was a loose wire ,the snow must have put it back in place.... all secure and good now!
a win is a win. user error (most likely) and not a costly repair
2001ATL
