Singtoe
Let the critiquing begin...
All this talk about a home made adjustable panhard bar has me wondering if a decent homemade one can be made.
Here is what i came up with.
The OEM panhard tube is actually quite thick. It is 0.135" thick. It was much to my surprise when i first cut it open. As you can see in the picture, it is not DOM. Notice the seam where it was folded over and welded.
Now, What to use for the adjustment part. Hmmm. I wanted to be able to adjusted mounted on the car but a I could not find a Left hand rod. So I would be stuck just using single threaded rod and would have to remove one end to do the adjustment. Now what thread rod would be strong enough. Then I thought about using a tie rod.
I had some old inner and outer tie rods for the front of the 4runner and if it is strong enough for the front then it should definitely be strong enough for the rear. The Shaft diameter is 20mm. Best of all, these parts were free.
What I did was cut off the tie rod so that when it was inserted in the panhard end, it would extend inside and actually lock into place in the oem taper.
I used an axle nut that was tapered already and threaded it on to the rod and spot welded so it would not ruin the temper of the tie rod. Then I welded the rod nut assemble to the OEM pan hard bar.
I took the inner tie rod end, cut the ball socket joint off and turned down the joint to fit inside the OEM panhard bar.
Kind of similar to a bung fitting.
I welded it it on the OEM panhard bar and threw some paint on it.
Now the final assembly.
