EEtM33t said:I've finally received my cornfed lift!
It did not take too long to get here but it will take longer for me to get around to installing it and the wheel spacers...
c04rsx-sm said:when did you order this kit, i ordered a 2/1 on october 2 and have not recieved anything, :nono:
Hayn4R said:how much did this lift cost, with shipping?
how much for the wheel spacers? What is the advantage of using these wheel spacers?
Do they just make the stance wider? Is there a disadvantage to spacers?
J.A. said:You had CF custom make a 2.5/1.5 lift? If so please measure the front preload and front top out spacer thicknesses, thanks.
c04rsx-sm said:for real though, when did you order your kit?
EEtM33t said:I will this weekend once I find a ruler.
You want photos of them as well?
J.A. said:There is no ratio to apply for the rear. If you want 1.5" the spacer needs to be 1.5". Having one spacer at 1.75 is not really a bad thing as one side of the vehicle is always lower than the other, so just use the taller spacer on the lower side.
As to the front, all I can say is that the DS kit is 1" topout and 0.5" preload (opposite of CF) and that yielded 3" of lift. I am sure JasonB will give you the scoop as the 2:1 ratio is a estimate only...perhaps the 2:1 ratio varies weather it is preload or topout? Good Luck.
J.A. said:Quick question while you wait it out. What are some of the reasons for you to place a special order custom sized CF kit, knowing that DS makes that same sized kit for less money with quicker turnaround? Did you prefer Aluminum construction or prefer less topout? Just curious.![]()
