My DIY laptop stand
jrm27
My DIY laptop stand (the white-trash-catastrophe)
Hi all,
A few weeks ago I was scouring the internet for ideas on how to make a stand to mount my netbook in my 4runner. I wanted a way to mount my little netbook so passengers could watch movies and such during longer roadtrips. I saw some great ideas here, but wanted to try something a little different. Most of the mounts I found were made to be bolted into the passenger seat floor mountings. I didnt want to intrude on the passenger, and I saw a fella that had made something that I thought just might work that he had mounted in his cupholder. So, after getting a wonderful member here to verify the cupholder dimensions ( I hadn't picked up my 4runner yet), I set out to make my own!
Here are the parts I used:
-A Curved section of 2 inch PVC pipe.
-A 2.5 inch to two-inch step-down pvc pipe connector (wrapped in a few layers of duct tape)
-A 90 degree ABS elbow joint
-A plastic shower drain
-A small sheet of plexiglass (pre-cut)
-A Couple screws
-A hose clamp
-Some rubber coated wire
-Some cheap dash cellphone mats
Basically the curved two inch pipe would fit into the step-down connector to fit in my cup holder. Then the 90 degree elbow joint would go on the end, the shower drain would connect to the top of that, then the plexiglass would be screwed into the shower drain. Then.. voila... laptop holder.
To connect the plexi to the drain I simply drilled some holes in the plexiglass and then threaded screws through the holes and through the shower drain grate. A few bolts on the other side of the drain grate, and it was on there! Pretty easy.
Here's a pic showing everything:
3265fb6b.jpg~original
I would be using this for a long drive back from Dallas to my home, so I wanted a way to mount my phone on it since I use it as a GPS... I mean.. why not right? So, I just made a little mounting cradle out of some rubber coated wire and secured it to the PVC pipe with a pipe clamp. Super ghetto, but quite effective!
Here's some pics of the finished project...
From passenger side with computer and iphone all good to go:
5f30b165.jpg~original
From diver's side... with nothing on it it becomes a fantastic little table for hamburgers ; )
dd0cb105.jpg~original
In use with the phone acting as a GPS:
772c8a28.jpg~original
View from the backseat:
07466242.jpg~original
Ghetto iphone mounting bracket:
59075f8d.jpg~original
So, there it is. VERY GHETTO... actually, I call it my "white trash catastrophe", but it works perfect. It was really cheap too, probably under 20 bucks. I bet you could get by with less if you have some spare pipe around. This also isn't glued together. Everything is held together by friction and it is rock solid.
Thanks to everyone here who helped me out with info! What a stellar community!
-jon
Nice stand, are you going to paint it?
Cool A Dell with OSX :thumb3:
Thanks man! Naw, not gonna paint it. For what it is it is just fine. When not in use I throw it into the back of the truck and let it rattle around, so if it were painted it would just get scraped up anyways.
And yeah, OSX on the Dell Mini9 is awesome. It's like that little computer was made to run it... pair that up with PLEX and a portable hard drive and you've got a media station that can go anywhere. It runs like a champ!
Like your mount, you did a good job!
Just be careful, as in some states it is illegal to have a screen that is viewable to the driver.....in TX I know it is.
So just use a little tact and be careful......also don't forget it and leave it there for very long.....fat target for a thief.
how does it secure to the cup holder ? have you driven with a laptop on there ? how bad does it vibrate ? Im diggin it :lookout:
Yep, tact is the key. Actually it is right at the perfect level as it is pretty hard to see from outside the car while driving. In my jeep the netbook just sat on the dash, but now I can exercise a little more discretion.
It kind of "locks-in" to the cupholder when there is weight on it. It seems that the cupholder is ever so slightly tapered. So, it kind of jams in there. The duct tape provides a little bit of grip to the pipe too that increases the friction in the cupholder as well.
sweet hackintosh!
Where do you put your drinks now?
Thanks! I love the hackintosh ;) As for drinks... there is still one cupholder open, though it isn't the easiest to get a drink in and out of. So, I ended up either just holding it in my lap or using one of those cheap cupholders you can get at truck stops... you know the kind that slide into the driver side window channel? not the best solution, but with a long enough straw I didn't even need to turn my head to get a drink. Just leaned over ever so slightly to the left to stay hydrated!
Whew, I almost thought you got away without the duct tape! Glad to see you could work it in there! Super whiskey tango but well put together and very effective. I would call this a "prototype" :bigok:
No way! Even if I didn't actually NEED duct tape, I would have put it on anyway. I mean... to really be DIY it HAS to have duct tape ; )
cant spell great invention without the word duck tape in it! :banana: hahaha :D
i am going to give this a shot though! ive been looking for a good laptop mount like this for a while
also how long is that piece of curved pvc pipe?
shoot... I dont know how long that piece of pipe is... my car is in another state at the moment so I cant go out and measure. However, it is a standard piece of PVC that is carried at Home Depot over by the metal pipe fittings (not in the plumbing section). I think it is probably a lateral distance of about 13 inches.. maybe less... so from the drink holder to the end of the pipe is about that long. It would fit stock, but I took off about an inch with a hacksaw just to be safe. Didn't really need to though.
I can measure for you once I get home if you'd like!
that would be great if you could! ill go over to our local home depot to see if they have it! thanks again!
