My jaos bull bar....shakin a bit
schwalmy
hey team
any sugg on if the bull bar shaking is normal?
when im cruzin on the highway it seems to jiggel when ever i go over a bump
yet when istop at home it seems pretty solid
ive done a few searches but thought some one might have a tip or sugg
thanks in advance
schwalmy
I had a Waag bar and it did the same thing. The full size bars will always jiggle- I haven't seen one that doesn't a little. The obvious key is that they don't move enough to touch your truck and mark it. Double check that all your bolts are tight and secure. Also, most bars have a little play when it comes to aligning them. Make sure that the bar is pulled out as far from the truck as possible before you retighten any bolts.
My Manik is vibrating also. So it may be normal. If you are worrying about it, just give me a call and I'll take a look at it. ;):
Jaos CP
My Jaos center protector had a bit of play initially as well. After a couple of days I took a couple of wrenches to it again and it's been tight ever since (over one year).
roger that
ill give it a go tommorow
thanks for all the help guys
i hope i can do the same for u in the future
cheers
schwalmy
