My Rear Window Issue and the Strange Resolution
NJshadow93
A couple weeks ago, we had some warm weather by me and I wanted to open my back window. I was pretty upset when I realized it only went halfway down. I was worried it may have been the window may have been knocked off track or something like that.
Well, fast forward to last night. I put some pizzas in the back. They slid around a bit so I wanted to make sure they wouldn't come crashing out of the back when I open the hatch. I open the rear window with the key and to no surprise, it stops halfway down. It was then when I realized what the problem was. When the window stopped, the license plate kicked out a bit. Apparently one of the screws holding the license plate on was too long and was preventing the rear window from going down all the way. I pulled the license plate off, and the window worked perfectly. I cut about a centimeter off the screw with a hack saw, problem solved. Just thought I should post this up in case anyone else comes across this same, strange issue. I can now see the beef people have with Toyota designing the license plate to be screwed directly into the body. :cheers:
I like having the plate screwed into the body, except when those stupid plastic surround things start vibrating and it drives you completely insane! I can't use my rear window at all, until it goes into the body shop to have the tailgate replaced.
I've tried double-sided foam adhesive strips and even applying tension with thicker pieces of foam, damn thing still rattles!
Also to the OP, I have not seen this personally happen yet. But I don't doubt it from the way the threading for the license plate is done would allow that if you used long bolts.
You're lucky your bolt was just too long and not just the right length to let the window pass by the bolt and put a big nice scratch down your window. :bash:
I'd like to know who installed that bolt to begin with. Was it very long? A standard bolt shouldn't be long enough to do that.
I was thinking the same thing! It wasn't even a bolt, it was probably a 4 inch long screw, pointed end and everything. It's still in there now, but it's already cut. Wish I would've taken a picture of it before I cut it.
EDIT: This is what it looks like for the most part
Got this off of Google, sorry for the enormous pic.
guess you didn't read the mod for hauling pizzas flip the bottom of the back seat creates a nice secure place for pizza boxes
Well that sucks... those rear holes for the license plate are actually threaded for a bolt/machine screw and someone just ruined those threads with a wood screw. :rockthrow:
Well glad you didn't get a screwed up window and all is well!
Damn right! I'm not touching it now, I'm leaving it how it is since there's not much I can do about it now. Also, both holes are slightly different sizes too. The dealer I bought it from had to drill out a bolt that was suck in the other hole, which is probably why the sizes are different too.
I gave up and took the damn thing off, couldn't hear myself think with it rattling all the time! I tried super gluing it to the tag and it still rattled. Took it off and into the trash it went!
You see, this is why I don't go to (anymore) the dealer for simple stuff. My 18 month old daughter can do a better job. Though nowhere near as bad as this, one of the bolts froze on me. While getting it services (when I first had it), I asked for them to put a new bolt on. The jackass who did it, drilled into the old bolt and it fell into the tail gate.
He put a new bolt on, but now (since 2010) it rattles whenever I close/open the tail gate.
I'll get it out eventually.
lindwlson982
