my runner is having some electrical issues
r_xiong
hey every so like title of my post. i an having some problems with my 4runner. first my rear super doesn't work nor does my rear defrost or the window i can't open rear window unless i use key. the tailgate is kind of acting funny non of the electrical stuff seem to work on tailgate. secondly i can't lock the truck when the truck is off, the key from outside doesn't lock or unlock thedoors either. so if you guys can kind of help me out or lead me into the right direction that would be great because i am unsure of where to start. thanks and any info would help thanks again.
Search for hatch issues and youll find alot of answer especially about rear door ecu issues. Yours might need to be reset.
Check the wiring harness on the rear door...you may have a bad connection or broken wire(s).:beer:
i will try that man thanks because i check to see if it was because my back window wasn't closed all the way and i used the key and put it all the way up and still no response of my wiper working. so yup ill have to give that a try thanks man.
