Here are some progress pics. 4" full TG w/ 5" rears. Hopefully it won't be a Stinkbug, if so I'll remove a leaf. Tomorrow a.m. I'll install the brake lines, bleed then turn it around and start the rear. I mounted the hanger 3/4" forward to get my shackles vertical per my call to TG. Sure looks like my axle moved forward more than 3/4". Thanks to Beaters levers, I finally got two tires mounted and will do the others tomorrow. Overall the install is not too bad. I hope the springs come down some after some use, it's a little tall. Tires are used 35's. More pics to come.
Mostly finished. It's raining all day Sunday so I'll do some more later. I think I need to move the rear shackle mounts back another inch to get a little less angle. About 32 deg. now, too much for a new spring. The front angle looks pretty good so I can finish stitching the hanger.
I really didn't expect this thing to be this big, I'd better start flexin' it and break in the springs.
