My Screw Up, Parts Store or need a new Garage
ddoyle
Okay guys I have been pestering everyone on here for help with repairs... I was having issues with passenger side front brakes and folks on here said probably caliper. Got caliper and broke it down...had told my mechanic about the problem but he didn't come up with what everyone on here said right away. So when I took it down one brake pad was down to metal and into the rotor...other side fine.
Put on new rotor and brake pads...replaced caliper with part #C9920. Bled the brakes but read with ABS may need to take to mechanic. Brakes were soft so took to mechanic.
When got to mechanic first guy said bleeding it properly with ABS should fix it. Also stated with ABS anytime you get in lines you should do a full flush and fill. Said it would be $80...no problem. Then get call from another guy there saying it is a mess and the brake pads are shredded etc.. and we should probably replace both calipers because if one is bad the other probably is close. I had check pads on other side and the looked great. I said no and just repair passenger side. When I picked it up he said the #C9920 was to big. When I returned it to part store we double checked numbers said it was right and pads looked good.
They also used FRC11549 which in the parts store computer said it was for the driver side and that it was compatible with there part for the passenger side. Repair cost me $346.64.
So did I screw up repair, did part store give me wrong part or is my mechanic screwing me?????????
Sounds like another steellership answer to me. And your part didn't say TOYOTA on them.
I presume that fix your problem though.
Sorry to hear this.
Found another thread saying the C9920 is the wrong part listed at Autozone for the truck and that thread says it is to big....but think he misrepresented that it was doing all kinds of damage!
It sounds like who ever sold u the c9920 sold u the wrong ones. These calipers are a mystery to some aftermarket parts store, what u need to look for is a casting number on them (13WH, 13WG OR 13WL).
Sorry to hear this.
Sounds more like he's talking about an independent shop than a Dealership.
Also to the OP, I'm assuming you're talking about a 4th gen 4Runner (as you did not post in any generation specific forum, did not provide vehicle information, but I was able to trace the part number you gave us; in the future this information is very helpful for us) in which case you need to find out WHICH caliper you have. Is it the smaller set that came standard on SR5 & Limited models? Or the "Sport" brakes that came on the Sport Editions and optional on Limiteds; this is very important as the two are not interchangeable. Something else to point out is that I have never seen a caliper that is designed to fit on both the driver's AND passenger side, the reason is because normally if you flip a Driver's Side Caliper to fit a Passenger Side Hub, the bleed screw will point downwards. Now I could be wrong and the 4Runner calipers are different, I genuinely have not tried to reverse them before so I never paid that much attention to it.
Here is a breakdown of the Brake Caliper Casting Numbers:
Caliper 13WH- 13.3"/338mm rotor diameter
Caliper 13WL- 12.6"/319mm rotor diameter
Caliper 13WG- 12.6"/319mm rotor diameter
2001ATL
