woah woah woah
WHERE SPECIFICALLY is it rubbing?
if its the pinch weld ( the fender that is by the drivers left foot), then you can cut and pound it in.
if it is the front drivers side, you can take a box cutter and cut some of the flare/trim off.
id recommend exchanging those rims though unless you plan to lift/wheel it... in which case id say you need to get some spacers or a BL till you can deal with it more.
