Mystery part - fuel line shield?
4x3Lander
Looking around for the "tinny" rattle I would occasionally hear under the rig, I saw this metal piece and barely grabbed it before it decided to part ways with my rig's body. It looks like it was a fuel line shield?
I think rear heater line as well. Were the lines go back up into the cabin. This is on the passenger side just inside the frame rail.
Sent from my Nexus 6P using Tapatalk
+1 on the rear heater coolant line shields. It protects the rubber hoses that attach to the steel lines that run to the rear - the rubber lines go through the floor to the heater unit mounted under the right front seat.
I got a good look at that when I replaced my rusting and nearly leaking 96-00(?) steel hard lines with some nice shiny non-rusting 01-02 lines I got from a junkyard.
Given how rusty that shield is, I'd be looking at those steel lines real carefully on yours if I were you unless you have an 01-02. The pain bubbles, trapping moisture underneath, and eventually, pinhole leaks will leave you stranded with an overheated motor.
Thanks everyone. All of that sounds correct. I will check the lines. My rig is a 2002 and if I recall correctly, the lines weren’t rusted. I’ll check when I get a chance.
Without checking, I’ll also need to see how easy it would be to mount a replacement.
seltzernator
