N00b question...and obligatory pics
g8rdmd
Hey all, I'm new here and new to the T4R world...
Just picked up a 2002 SR5 4x4 with 147k miles :banana:
front.jpg~original
side.jpg~original
rear1-1.jpg~original
Mates.jpg~original
Now for the question...Do you guys run continuously in 4wd, or only switch when conditions warrant, like rain, snow, off-road, etc.? Does it hurt anything (other than MPG) to keep it full-time in 4wd? Pros, cons? Thanks, I've been enjoying lurking here and soaking up the info :thumb3:
Do not run it in 4wd above around 40 mph or on pavement. You will burn up your transfer case... (pretty sure your truck doesn't have a locking center diff, if not, someone will correct me)
Leave it in 2wd unless in low traction conditions. Use 4wd in Low Range when operating in rough terrain.
It actually does have a locking center diff that I can switch on/off...does that make a difference? I'm new to the 4x4 world :cool:
All '01 and '02 4x4s came with the multimode 4wd system (aka center diff lock). When you're in 4hi with the center diff unlocked you can go up to like 80 mph+. It's fine to use this type of 4x4 on road, it acts like AWD. But, in dry conditions if you drive around in 4x4 you're wasting gas and eating up your tires. Use it as needed:
Dry: 2wd
Wet: 2wd or 4Hi/center diff unlocked
Patchy snow or ice: 4Hi/center diff unlocked
Snow or difficult off road: 4Hi/center diff locked
Deep snow very difficult off road: 4Lo/Center diff automatically locked when in 4Lo.
Dry: 2wd
That's exactly the run-down I was looking for...thanks!
