kubes71 said:
Hello everyone!
What cell phone / carrier works best with the bluetooth Navigation?
Thanks!
Bluetooth (BT) is an open standard governed by a SIG (special interest group). What it comes down to is not so much the carrier, but what the manufacturer of the phone has decided to implement for the Bluetooth profiles. Arguably, there are some phones and headsets that have better Bluetooth performance than others.
What I mean by profiles is there has to be certain functionality for BT to work, i.e. all phones will have the headset profile, which allows BT to send and received audio, earpiece and mic sounds. There are other profiles, like on computers transferring files, printing, etc. that may or may not be supported by the phone. Depending on the BT profiles implemented on the phone and Toyota's nav unit is what will limit the functionality and interaction on between phone and nav.
I believe this is what the class action suit against Verizon was about. Verizon was sued because one of their Motorola phones has limited BT profiles and it did not allow the transferring of contacts/phonebook over BT. If the Toyota nav or your phone doesn't support this, it would mean you would not be able to dial contacts frorm the nav system (assuming the Toyota nav did support it and the phone does not).
I'm currently using a Treo650, so most BT profiles are supported because it's a PDA phone. Some of the camera phones my carrier (Sprint) has supports PictBridge printing and file transfer over BT--it really depends on the phone. But if it's a regular phone you may want inquire about the BT profiles that is supported by the phone and match it up to the BT profiles the Toyota nav has.
Ask around with people in the areas you're most frequently in and see how they like their coverage with their carrier. Most carriers offer some type of trial period for their service. So if the phone or the coverage doesn't work out for you, you can always cancel and avoid the early termination fees.
Hope this helps. Good luck.
