Navigation System have Subwoofer out?
schoeps
Anyone know if the 2010 nav system will have a sub woofer out? Is there a pdf manual out there?
Thanks!
schoeps!
but does the receiver have an isolated subwoofer out?
SORRY MODS FOR WRONG FORUM! I JUST FOUND THE OTHER :)
maybe I dont understand the question, the subwoofer connects directly to the stereo component amplifier assembly.
I am looking to install another amplifier to power a seperate subwoofer and wanted to know if there was an isolated subwoofer signal coming out the back. I have been scouring the interweb looking for some images or a manual but am coming up with nothing, mainly because I do not have a part number ;)
Thanks for getting back to me!
Bri
you could always run a JL amp in there. they dont need a remote power line to turn them on. they can be turned on via power being sent through the rca cables for the amp, so you can run a sub and amp with a factory stereo.
they also do this so you can run multiple amps off of each other without having to splice and connect remote turn on lines for them
I dont think I have ever seen or heard of a factory head unit with a dedicated subwoofer preout...
x2
You could get a line out converter and create a set of RCA outputs that way, though it will never sound as good as a HU with built in RCA outs.
S JL audio is the OEM equipment? Where is the amp itself located?
Thanks so much for the infos!
Bri
Nevermind, I think I see what you mean here as an example. The amp I have has a crossover built in if I were to tap the FL/FR speakers. Thank you for getting back to me!
Bri
