Nee help on rims
hondaracer11
ok so i have 33x12.50s in my garage i want to wait on lift and get some steel 15x8 rims from summit and mount the 33s on it what do i need to help them fit? its for mall crawling not offroading much
remove running boards?
trim fenders?
thanks guys
trim fenders?
thanks guys
I have 32's and they clear fine, but i have no running board's or rear bumper. Sense your's are 12.50 wide i wouldn't put them on till you lift it. I was told they rub like crazy.
For mall crawling (and points for owning up :) ) a simple 2-3" body lift may suffice, and you may be able to keep the running boards. 10.50's instead of the 12.50's would also make for less work.
10.50 would be a lot easier. then you would only have to do a little messaging of the front inner wheel wells. but since you have 12.50s a lift is necessary or trim your fenders quite a bit
