Need a new front sway and links, OEM or upgrade?
Jester4kicks
Hey all, been a while. My runner is about to become my primary vehicle again, and I'm looking to make it a bit more drivable on the roads.
A few years ago, I removed my front sway bar to soften the ride a bit (had just installed my OME 885's and they were a bit stiff). They've since softened up a bit though, and the roll of death when turning is annoying.
The question is this; do I look for just an OEM swaybar, links, and bushings or should I shoot for an aftermarket setup? I figure the OEM would be cheaper (if I can find one), but the aftermarket might be better for the ~3" lift.
Thoughts?
Thoughts?
I have a set of front sway bar links from Mstudt that I never ended up using that I'll sell you.
I may take you up on that. Are they direct OEM replacements, or are they intended for use with a lift?
Direct replacement I believe, but can be used with the lift. Not sure if you need the relocation brackets or not. I never actually tried to line them up, sway bar came off and stayed off. Also have my sway bar and brackets if you need that too.
I have my OEM sway bar and All Pro adjustable End links as well if needed.
Thanks! I didn't mean for this to turn into a WTB thread, but I'll definitely PM you if Drunner's offer doesn't pan out.
Back to the real intent of the thread, did you upgrade to a different sway bar, or did you just remove the OEM and run without it? Just wondering if I should be looking at buying an aftermarket bar if I'm going to be spending money anyway.
utkrstam
