need advice for a leveling kit for my 07 2WD
Cracker Darrell
i've got 5th gen 20" limited wheels on 275/55/20 tires, which are about 1.5" taller than factory. the gap difference between front and back is killing me. i just want it to be as even as possible, that's the sole reason for wanting to do it. i'm not trying to do it to because i want to raise the truck up. what do i need? thanks.
I'd start experimenting
with 1/4 & 1/2 spacers till you hit nirvana. You could also use a larger spacer and remove material until its "even as possible"
I had the daystar budget boost on my 4Runner and it lifted it up a bit. Cost me $40 dollars to buy it and then had to pay for install but you could easily do it yourself. If you're looking to buy a daystar budget boost i have a set for sale because I just installed a 3 inch lift.
This is the kit I got:
Daystar? - Driven by Design
(Just 2 Spacers and 6 bolt extender) PM me if you want it
This is when i just got it installed. There is still a bit of a rake. But if you are just thinking of lifting the front a little bit this will probably work
do you have a picture? is this a 1" spacer as in it lifts the vehicle up 1", ex. the spacer is 0.5" which achieves a 1" lift? or is it a 1" spacer which achieves a 2" lift? hope that makes sense.
Sorry I haven't gotten back in a while, college has had me pretty much tied down for the past month. The way I understood it (someone correct if I'm wrong), the spacer is 1" but it lifts the front 2".
Before:
After:
Also, I apologize for the weird angle for the after picture. Best I could do at 1 in the morning haha.
