Need advise...tow capacities and hitches
Here are a few pics of mine. Stock.
[/url]Untitled by turnnow, on Flickr[/IMG]
album-72157651118830608
The pics you posted are of the V6 standard duty hitch. It is rated for 500 lbs tongue weight and a max of 5k towing weight. It would be ok for light towing (small trailer, boat, or utility trailer). It is not compatible with any type of weight distribution tow bar. I wouldn't necessarily call it "undesirable". It will work well if used within its limitations. If you want to tow heavier loads, then a frame mounted aftermarket hitch will be needed.
Sorry I know this is an old thread but is it worth it to replace the original receiver with an after market frame mounted class 3? Does a distribution hitch make a big difference with a 3000 - 3500 trailer.
Yes. I towed a 2000# pup on a V6 Rav4 and it made a huge difference. On my 3rd gen I installed a WDH compatible frame mounted receiver and towed a 3800# pup as well. It levels the 4R and distributes the weight across all the axles. I wouldn't tow a trailer without one. It makes towing a safer experience. That and some air bag spring helpers for the rear. Makes the ride much smoother.
Sent from my Nexus 7 using Tapatalk
