Need answer about toytec/lift measurements ASAP please!
00_4runner
Hey guys I installed my coilover and 891 toytec full lift on friday and had a quick question. When I went to firestone to get it aligned the guy at the shop was measuring the differences in height in front from where the shock bolts to and then to the frame. One measurement gave him 2 1/4 and the other was 2 1/8, he told me to even them out before I do the full alignment. My questions is do I have to have this perfect? Is it a problem if the measurements are about the same all around or should I be running exactly equal amounts everywhere? I feel like an eighth of an inch does not affect much. Im going at 8 AM so if anyone has a response that would be great! Thanks in advance!
I don't think it matters as much on the coilovers themselves as it does ground to fender. If ground to fender are equal then you're good to go.
By equal does that mean perfect? The passenger front sits a little less than a 1/4 in higher than the driver side.
Get it as close as you can because thats without you sitting in the car so it will be further off with you inside.
