need help finding weird noise
pflfw
i have a 1997 4runner sr5 4x4 automatic transmission, about two weeks ago i started hearing a what sounds like really bad tire noise,almost sounds like you are riding around on a flat, the noise comes and goes some days worst than others. i checked the tires they all seem ok, rotated the tires noise didnt change, occasionally while slowing down and accelerating there is click or pop that sounds like it is coming from the rear end(mostly under light braking)cant really tell where the noise is coming from (front or back)it does at all speeds over 10mph but it quits about 75mph.all four tires are set at 29 psi,have messed with different pressures and does not change. any help here would be nice thank you, also i have only had the truck about a month and half it has 142000 miles on it thanks again
problem found
took truck to a mechanic who found that the passenger side rear wheel bearing was bad after changing that now there is no more noise, hope this helps any one else with simular noises
