Need Help Post Off Road Rattle/With Video
hagan39
Did some heavy trail riding last weekend Jellico area of KY. Lots of rocks but wasn't too hard on anything. Left with a nice rattle after I got home. Checked sway bar bushing, steering arms look good. Visually everything checks out.
Took a video of it, yes its upside down, any suggestions? Def hear the rattle around 2:50 mark of the below video
https://www.youtube.com/watch?v=nHUAxOC5Uwg
Did you check the skid plate bolts? I was in Big Bear last weekend and after hitting some trails one of my skid plate bolts had backed out quite a bit and was making a similar noise.
Yeah, hard to say, my first thought was a pebble caught up in some place like a brake dust shield, a skid plate, or similar.
Yea id guess something is loose - hard to pinpoint one loose bolt out of a 100. Check skid, calipers Any recent upgrades or maintenance work. Check your muffler/ exhaust, the spare tire carrier
Good luck
Id check to see if there is any rubbing with the dust shields/ backing plates behind the rotors. If there is, your backing plate will have some heat after driving and there should be metal scrape signs. Easy fix by just bending the sheet metal a little.
AndiGarage
