Need help! Shudder w/ overdrive
Jpete16
I have a 97 3.4 automatic 4wd. It has a random shudder that most often spread at 45-60 mph. It had become more frequent lately. I drained my transmission fluid and replaced it with withclean fluid. I have found that when I turn off the overdrive the shudder doesn't happen. I'm curious if this could be something other than a transmission issue? Is there harm running with overdrive off, or just worse gas mileage?
Any help would be great,
Thanks guys
If the shudder happens under light throttle in overdrive my bet is it's your spark plugs. They are probably worn to the point that it throws the timing off just a hair. This happened to me and many others and changing them got rid of the shudder.
AndiGarage
